Online Now [183]:
Visitors: 182
Today: 10139
Total: 143319134
Forums › The Car › 206 Problems › Low coolant warning at certain temperature
Searcher
PostPosted: Sat Apr 23, 2016 9:46 am Up
Hello,
My 2002 1.4hdi 206 has started throwing Low Coolant temperature warning during temperature range of approx. 65 to 75C or I would say from a little bit less to a little bit more than 70C mark. Once reached to normal temperature it becomes fine again. Coolant level is fine and a couple of months ago I had new Cambelt and Water pump.
What would be the likely culprit?
Thanks in advance to any pointer.
Searcher
PostPosted: Sat Apr 23, 2016 2:17 pm Up
Just to update, I removed the connector to level sensor attached to overflow bottle and sprayed it with WD-40 to get better contact. It has apparently solved the problem. Shall add further updates should the problem return.
Searcher
PostPosted: Tue Jun 21, 2016 5:57 pm Up
Hi,
The WD-40 only worked for a day or two and the problem is still there. A bit intermittent though.
I have also noticed that slow fan does not kick-in without turning the AC on.
Any suggestion where to start? resistor, relay, sensor etc.
