Online Now [244]:
Visitors: 243
Today: 47126
Total: 142759461
Forums › The Car › 206 Problems › Car cut out now not starting numerous fault codes.
arronc
PostPosted: Sun May 01, 2016 5:33 pm Up
Hello
My beloved Peugeot 206 1.1 cut out today and is refusing to start. It turns over fine but will not even attempt to start. The EML is on and the following codes are being thrown up.
P0261 Injector 1 Low Voltage
P0267 Cylinder 3 Injector Circuit Low
P0270 Injector 4 Low Voltage
P0264 Cylinder 2 Injector Circuit Low
P0135 O2 Sensor Heater Circuit Malfunction
I have this week had the coil pack replaced and battery. The spark plugs are also only about 5 months old.
I have had greenflag out who tried a couple of different coil pack but again it would not start up. They have confirmed that fuel pump is working fine and cambelt is not skipping. They checked all the fuses and looked at a few groundings. They suspect it may be the coil pack wiring but only suspect.
With the above codes is there anything else I should be looking at.
Thanks for your advice it is really appreciated.
PostPosted: Wed May 04, 2016 4:23 pm Up
Unplug your 02 sensor and see if that sorts it. Had this a few years ago, turned out to be an earth short.
arronc
PostPosted: Sat May 07, 2016 4:20 am Up
Hello mate thanks for the reply. Just disconnected both but still no change. The battery is showing as 12.06 volts although it is only a 2 weeks old so just giving it a charge and will try again. However the battery reading when it broke down was fine.
