Latest: Kifi69
Overall: 17183
Online Now [452]:
Visitors: 451
Today: 46843
Total: 144506664
Forums › The Car › 206 Problems › Gti 180 oil leak help
cainw1
PostPosted: Sat Jun 04, 2016 11:21 am Up
Hi there ive read through a few threads about oil leaks but can't find one in this area. I have attached some photos hopefully this helps. Any help much appreciated!! I have changed the rocker gasket about 2 years ago.
It's obviously dripping onto the top of the gearbox as seen in photos and then off the bottom of the gearbox underneath
gpvecchi
PostPosted: Sat Jun 04, 2016 11:47 am Up
Mine has a leakage from the cammes timing sensor, that is located there
Silver grey RC|Pug Sport remap|Group A induction|Supersprint backbox|lower strut bar|RCCup wishbones|Eibach Pro-Street-S|302mm brakes+23.8 master cylinder|Vibra Technics|Quaife LSD|Cupra R splitter|modded bonnet vent|black Valeos|207i tail lights|Chromed rear foglight|Bi-xenon 6000k+all led (in+out)|406 rear mirror
cainw1
PostPosted: Sun Jun 05, 2016 7:58 am Up
Thanks for your reply. I've had a look at the actual sensor and the oil starts slightly nearer the back of the engine than the sensor and also a little bit lower down. There is a little oil on the hoses behind engine on the same side as the photo
cainw1
PostPosted: Wed Jun 08, 2016 7:04 pm Up
Any other ideas anyone? I've ruled out the cam sensor as there is no oil around it at all. If you look at the picture you will be able to see a puddle of oil ontop of the gearbox and then on the bottom right of the picture you can see a hose which has some oil on top of it. I am thinking it could just be the rocker cover again despite the fact I changed it two years ago.
Junglingo
PostPosted: Thu Feb 23, 2017 9:20 pm Up
Mine had a leak from the crankshaft oil seal. It leaked all over the bell housing
GTi 180 - Scorpion Exhaust
PostPosted: Fri Feb 24, 2017 8:19 am Up
It's not coming from either of the cam shaft housings is it? It can run between the cams near the spark plugs and run down the thermostat housing onto the gearbox.
cainw1
PostPosted: Sat Feb 25, 2017 5:20 pm Up
This was so long ago the leak actually reduced quite a bit now I think it was where I had filled the oil and spilt it around the edge it went under the rocker cover and down the side and thats why it looks burnt on to the block slightly.
