Latest: tebas93089
Overall: 17179
Online Now [110]:
Visitors: 109
Today: 5070
Total: 138313367
Forums › The Car › 206 Problems › Tappets
Tappets
Mikewhh
PostPosted: Sat Jun 18, 2016 7:33 pm Up
Hi I was wondering I have a 1.4 8v tu3a engine and was wondering if they have hydraulic tappets? If not how do I stop tapping noise?
PostPosted: Sat Jun 18, 2016 7:52 pm Up
No hydraulic tappets on a TU3.
There manual adjustment & must be set COLD - engine left standing overnight to cool down.
Number 1 cylinder is gearbox end.
You need a new rocker cover gasket & don't over tighten the rocker cover bolts as you will warp the cover leading to leaks.
FWIW: The stoneage mid 1980s TU engine design has always been a bit tappy.
Mikewhh
PostPosted: Sat Jun 18, 2016 7:56 pm Up
I not too confident in doing this roughly do you know how much it would cost for a garage to do it
PostPosted: Sat Jun 18, 2016 8:01 pm Up
I would suspect an hours labour charge would cover it.
It would be a simple job for an older mechanic to do.
Mikewhh
PostPosted: Sat Jun 18, 2016 8:08 pm Up
Ok thanks will speak to my garage bloke on Monday.
Mikewhh
PostPosted: Tue Jun 21, 2016 2:20 pm Up
The inlet valve lifters were loose
PostPosted: Sun Jul 10, 2016 8:45 pm Up
What did they charge? What parts used?
