Online Now [335]:
Visitors: 334
Today: 39710
Total: 142183889
Forums › The Car › 206 Problems › Rear Pad retainers/sliders rattling
cainw1
PostPosted: Tue Jul 19, 2016 5:12 pm Up
Hi there
Has anyone got any tips on how to stop the sliders/retaining pins on the rear calipers rattling?
If I try and move them they move forwards and backwards fairly easily but the pads are fixed well in position.
Incase I have got the term wrong its the metal bit that goes under the brake pads holding them in position.
Any ideas?
Cheers! Very Happy
PostPosted: Tue Jul 19, 2016 7:47 pm Up
Have you got little pins holding them in?
cainw1
PostPosted: Wed Jul 20, 2016 8:43 am Up
Thanks for your reply. Yeah the pins are in. On further inspection the pads actually move up and down a tiny bit when the brakes are off
PostPosted: Wed Jul 20, 2016 3:08 pm Up
What brand of pads are fitted?
Decent ones like Brembo, Ferodo or genuine PSA?
OR
Cheap s**te like Power Train, Drivemaster, EBC?
PostPosted: Wed Jul 20, 2016 8:02 pm Up
The pads should be quite a snug fit. My little wedges need to be lightly tapped into place as there is no free play between pad and wedge.
cainw1
PostPosted: Thu Jul 21, 2016 2:22 pm Up
Thanks for the message again Edward.
I have figured the problem out there are no anti rattle clips on the rear pads, so I have some coming tomorrow.
The point at which the pad rattles is exactly where the clip goes over the top so it should be gone after they are fitted!
PostPosted: Thu Jul 21, 2016 6:04 pm Up
You talking about the big paper clip type clips? I didn't think they actually did much.
cainw1
PostPosted: Thu Jul 21, 2016 6:46 pm Up
Yep the big clips. Its weird because my old pads didn't rattle without them, but I can see if there was a clip on top it would stop these ones moving completely. Fingers crossed!
cainw1
PostPosted: Sat Jul 23, 2016 3:24 pm Up
Fitted the rattle clips today and problem solved! Certainly didn't break the bank
