Latest: Stu-mill
Overall: 17131
Online Now [60]:
Visitors: 59
Today: 74108
Total: 104882921
Forums › The Car › 206 Problems › Saving radio settings when changing the battery
AJAC
PostPosted: Fri Aug 26, 2016 11:11 am Up
Hi
PostPosted: Fri Aug 26, 2016 1:20 pm Up
A 2003 model has a VIN coded radio so there is no code needed.
pAvax
PostPosted: Fri Aug 26, 2016 1:57 pm Up
That said, if you have an older model with a radio which requires the code, where can you find this code?
Oh, and I am quite buggered anyways, as my top display doesn't work. Embarassed
Current project: Ciri
Silver 206cc - 2.0 - 2001
PostPosted: Sat Aug 27, 2016 8:19 am Up
Also the OP is very lucky not to have crashed the BSI software OR killed the BSI unit by not following the correct shut down & boot up procedure on a multiplexed 206.
