Latest: lio94
Overall: 17181
Online Now [55]:
Visitors: 54
Today: 9631
Total: 141320419
Forums › The Car › 206 Problems › 2006 1.4 hdi won't start
Go to page Previous  1, 2
PostPosted: Thu Sep 22, 2016 2:55 pm Up
Are you sure on no fuel pump in tank?
JeroenB
PostPosted: Fri Sep 23, 2016 8:23 pm Up
Fuel pump is driven by the timing belt.
No pressure on the high pressure line, could this be the valve? Sensor has 2 connectors 3v and 12v.
Are these the right values? Can't seem to find confirmation.
I think I cant wipe the errorcodes, new errorcode pops up from when I disconected the airbox, tried to delete codes, no luck.
I can use my Delphi to test some components, like the fuel valve, but no response also.
Is there a reason why I can't access the ecu, wipe it?
Tried to look for peugeot planet, does anyone have a link where to get it for Windows?
Thanks,
Jeroen
PostPosted: Sat Sep 24, 2016 8:55 am Up
Peugeot Planet / Diagbox software is easy to find on the internet BUT without the Lexia interface the software is useless.
JeroenB
PostPosted: Mon Oct 03, 2016 10:18 am Up
So after letting the peugi sit for a while I looked at it again.
Tried other OBD software and thats also not able to wipe the fault codes.
(like air flow meter, fuel volume meter that I disconnected before)
I can diagnose module except for the "EOBD" module, the program says it isn't responding.
Could this be because the car is in ECO mode?
Jeroen
PostPosted: Wed Oct 19, 2016 12:50 pm Up
according to what you said,you have air enter the system,and air block will cause a no starter engine,so you need to know where the air enter the system.
PostPosted: Wed Oct 19, 2016 2:40 pm Up
Jeroen
Sounds like the immobiliser is active which would block access to the engine ecu which is why it wont respond to being probed by diagnostic tools.
Global scan on Peugeot Planet is the next step forward & see what faults are reported / stored.
Page 2 of 2
