Latest: jackrox1992
Overall: 17186
Online Now [660]:
Visitors: 659
Today: 182289
Total: 147890484
Forums › The Car › 206 Talk › 206 quiksilver with lumpy start
Forum Index › 206 Talk
mikeF00
PostPosted: Mon Oct 03, 2016 7:42 am Up
Hi, I've had my 206 for over a year now, and I've never been happy with it when I start from cold. It always feels 'lumpy' like it's about to cut out or stall.
Any body got any ideas?
PostPosted: Mon Oct 03, 2016 8:20 am Up
Tell us which 1 of the 5 different engine options your Quicksilver has fitted & we can advise you further.
mikeF00
PostPosted: Mon Oct 03, 2016 8:39 am Up
Hello again. It is a 2004 1360cc petrol
PostPosted: Mon Oct 03, 2016 12:04 pm Up
Well for a start you can clean the throttle body,and make sure everything working well in there,then if that don't fix the cold start,you can check the spark plugs,and also the coil,and most of all you need to check the fuel filter,when was the last time you replaced it?as you might have a clogged one,which leads to a bad start specially in the morning,as when the fuel pump prime the engine don't have enough fuel to start as it should.
Good luck,keep us posted please so that you can solve this,but if you disappear,and leave no further comments on the situation,then I'm afraid we can't help you right away.
PostPosted: Mon Oct 03, 2016 12:52 pm Up
Narrows it down to 2 different options.
8 or 16 valve?
