Latest: tebas93089
Overall: 17179
Online Now [299]:
Visitors: 299
Today: 47670
Total: 138013004
Forums › The Car › 206 Problems › Mfd bulb problem
Mfd bulb problem
adamwestlondon
PostPosted: Wed Oct 12, 2016 6:10 pm Up
Hello, I have a 2003 206 and am currently experiencing a problem with my mfd. Yesterday it suddenly went dark. The bulbs are not working. I put 3 new bulbs in and still nothing. Checked the fuses which are all fine so decided to check if there's any current going through the power bar for the bulbs. There is power running through it so I'm now at a dead end. Can anyone please help me?
PostPosted: Thu Oct 13, 2016 4:55 am Up
Did you put the bulbs in with the power switched on?
VorTechS
PostPosted: Thu Oct 13, 2016 9:26 am Up
Staff - Vortechs
MFD has a common problem where the connectors / tracks / pins break over time.
There used to be a thread about repairing them: 206info.co.uk/Forums/v...t=206.html but the images are all dead which is a shame.
pAvax
PostPosted: Thu Oct 13, 2016 12:51 pm Up
I can post a solution to the pins if anyone needs it?
It is a bit... 'hacky', however it works... It bypasses these pins completely and goes straight onto the metal of the bulbs (which is where the pins would end).
Two small cables, quick soldering task and voila.
It works handsomely too, now if only all pixels in my display simply displayed...
Current project: Ciri
Silver 206cc - 2.0 - 2001
adamwestlondon
PostPosted: Thu Oct 13, 2016 2:58 pm Up
no the power was off. I have checked the board where the bulb holders connectors touch and there's power running to it but bulbs dont come on
adamwestlondon
PostPosted: Thu Oct 13, 2016 3:01 pm Up
The lcd screen and radio both work but bulbs don't come on. Does't make sense to me. I dont want to take it into peugeot as suggested by my mate as the money it will cost wouldn't be worth it.
PostPosted: Thu Oct 13, 2016 6:03 pm Up
I have the hard drive these pics on are. Maybe someday i will plug it back in and update the thread Laughing
adamwestlondon
PostPosted: Fri Oct 14, 2016 1:46 pm Up
Thing is there are no breaks. It was working but after it was disconnected and reconnected they stopped working. power is going to the contact points of the board to where the bulb holders connect
adamwestlondon
PostPosted: Sat Oct 15, 2016 10:45 pm Up
Problem sorted. Replaced all bulbs again with new ones. working now
