Posted: Sat Nov 12, 2016 4:39 pm |
Can anybody confirm the correct torque that should be applied to these water pump bolts? It's not mentioned in the Haynes manual but I've managed to find something that suggests 14Nm is correct. Can anybody confirm this is correct?
Posted: Sat Nov 12, 2016 5:11 pm |
This any help?
Posted: Sat Nov 12, 2016 8:16 pm |
That matches the website I found so that will do for me. Thanks!
