Online Now [1332]:
Visitors: 1331
Today: 229747
Total: 146374490
Forums › The Car › 206 Talk › Broken into
Broken into
Forum Index › 206 Talk
Go to page Previous  1, 2
PostPosted: Wed Nov 23, 2016 7:15 pm Up
Good 2nd hand lock set & window.
Repair bent part of door.
Leave paint.
If you take it the insurance way they will write that of as beyond economic repair.
commandosqueak
PostPosted: Wed Nov 23, 2016 11:41 pm Up
Thats what I was thinking! I rely on the car to get to uni so really can't have it written off. I have spent several hours on the road today to collect some glass from spud, Cheers buddy much appreciated! Found a complete lock set for £35 and I will leave the paint. So total it's less than the excess would have been. The only issue I have now is fitting the glass. The Mechinism seems to be jammed so I cant lower it. As you all probably know the mech needs to be at least half way down to get the clearance. If I can free it up without drilling the rivets I can fit the glass myself. I have read the haynes manual and it appears to be really simple. Any one have any suggestions?
2003 206 1.4 HDi (3 Door) LX - Cypress Green - KQM
2003 206 SW 2.0 HDI Grey
commandosqueak
PostPosted: Thu Nov 24, 2016 7:40 pm Up
Out of interest if i got something along the lines of this. Would I have issues with key coding and the immobiliser assuming i transfer the chip and central locking electronics?
PostPosted: Thu Nov 24, 2016 7:55 pm Up
Could always just get a new key blade cut to the new lockset so you use the original remote fobs.
The standard non remote key does come apart to allow the immobiliser chip to be removed BUT the key cap is a tight fit / difficult to split.
commandosqueak
PostPosted: Thu Nov 24, 2016 8:04 pm Up
Thats essentially what I would do. Replace all the locks but use the exsisting central locking electronic and the immobiliser chip. Im just worried about the ignition, is the key read by the ignition barrel or the ecu? essentially i just need to know if the change the ignition barrel will i have problems?
PostPosted: Thu Nov 24, 2016 8:15 pm Up
The immobiliser aerial just clips around the ignition barrel.
The barrel is just a mechanical lock.
commandosqueak
PostPosted: Thu Nov 24, 2016 8:16 pm Up
Thats what i thought, thanks. Wanted it confirmed before i purchased the locks.
Page 2 of 2
