Online Now [219]:
Visitors: 218
Today: 65494
Total: 138995883
Forums › The Car › 206 Problems › Regassed Air Con is really noisy
CarlDuffin
PostPosted: Thu Jan 12, 2017 8:33 pm Up
Since my Air Con was re-gassed it has sounded like an old refrigerator on a hot day and that is whatever the weather with the AC switched to just normal temps, not super cold or over warm.
Back to the garage?
owlinbrum
PostPosted: Thu Jan 12, 2017 10:35 pm Up
Mine made a loud banging noise after regassing and it turned out it was over-gassed. When it's been low in the past I've heard a whining, perhaps hissing occasionally, then no noise as the clutch wouldn't kick in due to pressure being too low. You can get pressure testing and regassing valves from Halfords to check, but if you've just had it done I'd go back to them and get them to double check it.
