Latest: Kifi69
Overall: 17183
Online Now [451]:
Visitors: 450
Today: 139672
Total: 144599318
Forums › The Car › 206 Problems › Valve bounce
Valve bounce
Mikewhh
PostPosted: Sun Jan 29, 2017 7:42 pm Up
Hi I recently had an expensive visit to peugeot because my throttle body went wrong, they have told me I have I odd valve bounce and they are unsure why it is doing it, my revs bounce a lot lower than they should and it does not bounce quick enough. It is worse when cold. I was just wondering if anyone has had this or knows how to fix? Any help would be appreciated, thanks
PostPosted: Mon Jan 30, 2017 9:06 am Up
Valve bounce???? Or do you just mean the revs are dropping too low?
Mikewhh
PostPosted: Mon Jan 30, 2017 10:46 am Up
When I put my foot to the floor it hits about 4500 and revs bounce
PostPosted: Mon Jan 30, 2017 12:30 pm Up
Rev limiter controlled by engine ecu.
It's virtually impossible to get valve bounce on a fuel injected engine.
PostPosted: Mon Jan 30, 2017 2:32 pm Up
So it hits the limiter at 4500 rpm?
Mikewhh
PostPosted: Mon Jan 30, 2017 5:10 pm Up
It hits 4500 then drops then goes upto abit higher then drops, this repeats all the time the accelerator is filly down
