Latest: Beduff1977
Overall: 17134
Online Now [1243]:
Visitors: 1242
Today: 23757
Total: 107959123
Forums › The Car › 206 Problems › Full Size Spare Wheel
jimsigs
PostPosted: Thu Feb 09, 2017 3:57 pm Up
Good afternoon All,
Have just obtained a full size alloy 15" wheel for my 2004 Pug 206.
Fitted in the cage, but a very tight fit. I have seen on this forum suggestions that its best to adjust the cage to its lowest position in relation to the chassis. How is this achieved ? Is there an adjustment somewhere which I have missed or is lowering the thread screw what is meant.
Can anyone please explain
Regards
Jim
PostPosted: Thu Feb 09, 2017 4:17 pm Up
Unclip the front of the cage & move it down to the lower set of holes.
Grease the securing hook bolt thread at the same time.
PostPosted: Thu Feb 09, 2017 4:27 pm Up
Stick it in the boot instead and tie it in place.
jimsigs
PostPosted: Thu Feb 09, 2017 5:27 pm Up
Thanks to both MrBSI & Edward for your kind responses.
Will look at the cage adjustment first then decide on the boot option as well.
Regards
From an old ex Soldier 1949-72. Had a Puggy 403 when I was stationed in Germany
