Latest: Kifi69
Overall: 17183
Online Now [291]:
Visitors: 290
Today: 29350
Total: 144047265
Forums › The Car › 206 Talk › timing belt
timing belt
steviebee
PostPosted: Tue Mar 21, 2017 4:49 pm Up
Has anybody used a Gates timing belt kit? going to get the belt done in a few months on my 2.0 HDi. What is the recommended interval for belt change. I spoke to a peugeot dealer a couple of years back and they said 90K.
frenchie steve
gazza82
PostPosted: Wed Mar 22, 2017 7:58 am Up
Gates should be fine as are ContiBelt (Continental)
I think it's ten years or 90K ... which ever comes sooner although I'd be reluctant to leave one that long (I've had a cambelt fail ... or should I say the tensioner seized ... and it isn't pretty or cheap to fix!)
steviebee
PostPosted: Wed Mar 22, 2017 8:28 am Up
Hi Gazza82, thanks for that. It's just coming up to 78K. dosnt do a lot of milage and has an easy life. Do all the servicing/brakes etc myself, but I will leave the belt to my local garage (mates rates)
frenchie steve
PostPosted: Wed Mar 22, 2017 7:52 pm Up
Gates more often than not are the OE suppliers to Peugeot, i've pulled off factory belts badged up as Gates, and even gone into the parts counter at a main dealer and been given a Gates belt complete in Gates packaging over the counter.
Pretty easy to do a belt on the 2l HDi found in the 206. Few hours work at most really.
gazza82
PostPosted: Wed Mar 22, 2017 7:55 pm Up
2.0 diesel is easier than a 2.0 twincam petrol! Smile
PostPosted: Wed Mar 22, 2017 8:22 pm Up
I've done both.
Sim
PostPosted: Wed Mar 22, 2017 8:31 pm Up
Piggy did the diesel just like that www.youtube.com/watch?v=uFEyBus9Hxw Smile
EV (roadtripper)
Jag S(crapped)- & X-Type
GTC VXR (sold)
commandosqueak
PostPosted: Fri Mar 24, 2017 8:42 pm Up
Do you not need a special tension measuring tool to do the belt on the 2.0HDI?
2003 206 1.4 HDi (3 Door) LX - Cypress Green - KQM
2003 206 SW 2.0 HDI Grey
PostPosted: Sat Mar 25, 2017 8:45 am Up
The SEEM tool?
Most likely found covered in a layer of dust at your local Peugeot / Citroen main dealer workshop.
commandosqueak
PostPosted: Sat Mar 25, 2017 5:15 pm Up
hmmm so how would you test to make sure you have the belt at the correct tension?
PostPosted: Sun Mar 26, 2017 9:47 am Up
The twist test is perfectly fine for most timing belts.
commandosqueak
PostPosted: Mon Mar 27, 2017 1:53 pm Up
Cheers MrBSI, My uncles 307 needs it belt done. He has the same engine that in the 2.0 hdi 206
