Latest: lio94
Overall: 17181
Online Now [201]:
Visitors: 200
Today: 49746
Total: 141689418
Forums › The Car › 206 Problems › Centre console flashing - no battery disconnect
zebideedoodah
PostPosted: Tue Apr 04, 2017 8:49 pm Up
Hi
Just driven my 57 plate 206 HDI home from work when the centre console lost info and started flashing.
The only other post about this says it happens when the battery has been disconnected - but my battery hasn't been disconnected.
The car starts & drives ok. Is it likely to be a sign of a failing battery? Maybe an alternator problem?
I have reached the limits of potential guesswork, as you might have guessed. You all know a lot more than I do. Any ideas?
VorTechS
PostPosted: Fri Apr 07, 2017 10:23 am Up
Staff - Vortechs
More likely the beginnings of the main earth strap working itself loose....
gazza82
Flashing constantly or just intermittently? If the later I would suspect the pins that connect the two circuit boards are loose .. or maybe simply the plug on the top??
