Latest: cogeim7
Overall: 17185
Online Now [408]:
Visitors: 408
Today: 263979
Total: 147528634
Forums › The Car › 206 Problems › 206cc Aircon
206cc Aircon
killjoy
PostPosted: Mon Jun 19, 2017 12:28 pm Up
I have a problem with the aircon, it works fine except that I cannot set the temperature to less than 14 deg C, irrespective of the ambient temperature.
PostPosted: Mon Jun 19, 2017 2:24 pm Up
Is this the digital climate control system?
If it is then 14 is as low as it will go on the display, its just how the system is programed.
killjoy
PostPosted: Mon Jun 19, 2017 2:42 pm Up
Ok, I just never noticed before that the lower limit was that high.
PostPosted: Mon Jun 19, 2017 3:46 pm Up
14 is more then cold enough for the climate control system.
FWIW: The climate control on my mums Mondeo once you go below 16 on display just says LO
killjoy
PostPosted: Mon Jun 19, 2017 6:43 pm Up
Interestingly that's what my Qashqi says.
Danweider
PostPosted: Tue Jun 20, 2017 12:30 pm Up
I don't suppose any one knows how to re fill the air con, on a Peugeot 206 1.4 do they?
PostPosted: Tue Jun 20, 2017 3:44 pm Up
Take it to your local automotive cooling specialist or other place that does A/C.
A/C shouldnt be fiddled about with unless your trained, very easy to damage either the car or injure yourself
VorTechS
PostPosted: Wed Jun 21, 2017 7:37 am Up
Staff - Vortechs
Does anyone know how good the seals are on the 206 air con units?
Been about 3 years since I used mine, and whilst it looks like it fires up, there's obviously no gas there [it had run out whilst working those 3 years ago].
Considering taking a punt on getting it filled to see if the seals just might be okay, but I'm assuming they'll be shot.
PostPosted: Wed Jun 21, 2017 8:17 am Up
The seals will have dried up due to lack of use.
Needs a pressure / vacuum check before refilling the refrigerate.
VorTechS
PostPosted: Wed Jun 21, 2017 10:22 am Up
Staff - Vortechs
Figured as much. Ah well, it'll have to wait until I've got a bit of spare money available to either get the kit or get it done. For now, I'll just have to fry Very Happy
Sim
PostPosted: Wed Jun 21, 2017 8:45 pm Up
Some say, today was the last day of heatwave Smile
EV (roadtripper)
Jag S(crapped)- & X-Type
GTC VXR (sold)
