Latest: Kifi69
Overall: 17183
Online Now [392]:
Visitors: 391
Today: 84325
Total: 143744789
Forums › The Car › 206 Problems › ABS light
ABS light
thegentleway
PostPosted: Mon Jul 03, 2017 9:25 am Up
Hi,
My sister has bought a 2004 1.1L 206 with no service history. The brakes were worn out so I replaced them (front disc and pads, rear drums and shoes). I also replace the rear wheel bearings (the n/s was shot, wheel got really hot and smoked when she drove it home, fell apart when I took the drum off), and serviced it (oil, oil filter, cabin filter, air filter, spark plugs, couldn't find the fuel filter?!). All good so far but the yellow ABS light is always illuminated and when you drive it, the red handbrake light comes on and red STOP flashes. When you slam the brakes on the rear o/s locks up. I assumed it was the speed sensor so I jacked the rear up, put the handbrake on one click and span the rear wheels with the engine on: no warning beep on either side. I thought bingo, both sensors are dead. I cleaned the o/s rear speed sensor: still no beep. I replaced the o/s rear speed sensor but still no beep!? Does the 206 not beep when the handbrake is on and you drive off? The ABS light is still on and the rear still locks up when you slam the brakes but thought I would post on here before I replace any more parts in vain!
It's £75 for stealership to read the codes. Are there any suitable code readers on ebay for Peugeots?
Thanks for the help.
PostPosted: Mon Jul 03, 2017 9:48 am Up
Peugeot Planet 2000 or Diagbox is the dealer lever equipment.
You need a laptop with a 32 bit version of Windows to run it. I know it works on XP & Windows 7 ( I use 7 )
Software is easy to find free online, it's the Lexia interface & leads your paying for.
I have seen it reported that it runs on Windows 8.1 & 10 but never tried it myself.
Some higher end garage scanners will also read 206 ABS faults.
thegentleway
PostPosted: Mon Jul 03, 2017 2:35 pm Up
Thanks!
So I can just buy one like this one on ebay and I can do all the diagnostic Peugeot can do?
PostPosted: Mon Jul 03, 2017 4:42 pm Up
Basically YES everything the dealer can do APART from - You cannot download & then update any software on the car as you need log in details for the Peugeot software server.
cube
PostPosted: Mon Jul 03, 2017 7:34 pm Up
Sorry to jump in, is that one on eBay (above link) a safe/good one to buy ???
From China I mean ???
Only asking because I'm also after one !
206 1.1 independence 54 plate, 3 door
(West Yorkshire)
thegentleway
PostPosted: Tue Jul 04, 2017 5:55 am Up
Thanks MrBSI, that's very helpful.
Would be good to know where members have bought theirs, can you recommend any sellers?
Sim
PostPosted: Tue Jul 04, 2017 2:14 pm Up
I bought mine 2nd hand many years ago, it came with a damaged DVD. Got software from the internets and never had problems using it:)
EV (roadtripper)
Jag S(crapped)- & X-Type
GTC VXR (sold)
