Online Now [66]:
Visitors: 65
Today: 21468
Total: 116634080
Forums › The Car › 206 Problems › Brake line nut
Brake line nut
marone
PostPosted: Sat Jul 08, 2017 5:54 pm Up
Hi All
I'm attempting to replace the brake lines but I'm having difficulty removing the nut that connects the flexible hose to the solid pipe.
I have a set of flare nut wrenches but I'm finding that 10mm is too small and 11mm is giving a bit of slip. Seems if I put any force into it, it going to chew up the nut.
Currently have the nut soaking in some WD40 as after 14yrs it's coated in rust. I'm planning on trying again tomorrow.
Anyone have any thoughts or ideas how I can get the nut loose?
Also if I do damage the nut in the process, will I be able to obtain a replacement oem or aftermarket?
Cheers
Current: 206 GTi 180 2.0l
Previous: 206 XSi 1.6l
PostPosted: Sun Jul 09, 2017 10:00 am Up
If you are changing the pipes then cut the pipe near the hose union and put a long socket over the nut. Spanners open up and slip. The socket doesn't.
cube
PostPosted: Sun Jul 09, 2017 12:46 pm Up
There's loads of places in Leeds that sell the banjo bolts matey.
I used Beeston Motor factors (BMF) but their not too far from me lol.
Where are you if ya want hand or someone to say 'oh ya don't wanna do that" !! Pmsl lol
206 1.1 independence 54 plate, 3 door
(West Yorkshire)
marone
PostPosted: Sun Jul 09, 2017 5:56 pm Up
Cheers for the tip Edward, I'll give that a go.
I'm from Wakefield Cube, I'm sure there's a few places that have them around here then. Might look to get it swapped out as its looking tired.
cube
PostPosted: Sun Jul 09, 2017 8:59 pm Up
Cool, let me know if ya need a hand matey
(West Yorkshire)
gazza82
PostPosted: Mon Jul 10, 2017 12:51 pm Up
Try plusgas or a proper penetrating fluid .. WD40 is pants for really bad rust.
