Latest: jackrox1992
Overall: 17186
Online Now [767]:
Visitors: 767
Today: 198638
Total: 148719770
Forums › The Car › 206 Talk › Brake Fluid Capacity
Forum Index › 206 Talk
Danweider
PostPosted: Sat Jul 22, 2017 9:27 pm Up
Hi, just wondering if any one on here knows the capacity of the brake fluid, reservoir. I plan to drain the old fluid, and put new stuff in and of course bleed the brakes.
Dan
gazza82
PostPosted: Sat Jul 22, 2017 9:59 pm Up
You should be ok with a litre. If you have a hydraulic clutch bleed that through too .. same reservoir. I'd probably buy 2 litres to be on safe side.
Danweider
PostPosted: Sun Jul 23, 2017 9:53 am Up
Hi Gazza, thank you for your reply I appreciate it :). How do I find out if my clutch is hydraulic?
Dan
gazza82
PostPosted: Mon Jul 24, 2017 7:10 am Up
Check on the side of the gearbox at the front near the engine. The clutch release arm will have a cable attached to it or a small hydraulic piston operating a rod .. you'll know!
Danweider
PostPosted: Mon Jul 31, 2017 10:59 am Up
Thank you I shall do exactly this! Very Happy
