Posted: Wed Aug 16, 2017 4:16 pm |
hi all,
my 206 just failed MOT on emissions (again) and both front ball joint lower dust covers.
with regards the dust covers, are these available separately anywhere? so far seems like the whole ball joint has to be replaced?
emissions - really low CO and HC, slightly high fast idle at 1.05. both lambda sensors were replaced last year to get it thru. today a local mechanic took a look and said he can't find any exhaust leaks, but the post CAT lambda sensor was giving off dodgy looking voltage readings. faulty lambda again? does the low CO and HC rule out cat?
any thoughts?
gary.
Posted: Thu Aug 17, 2017 6:53 am |
The ball joint rubber boots are available as my GFs 206 required a pair for the MOT.
No idea where to get them from as my mechanic had a box full of assorted sizes of them.
Posted: Fri Aug 18, 2017 9:59 am |
Peugeot
361509 @ 1.76 each
