Latest: jackrox1992
Overall: 17186
Online Now [756]:
Visitors: 755
Today: 215383
Total: 147917980
Forums › The Car › 206 Problems › 1.4 8v 2002 oil in NO 1 plug
craggles
PostPosted: Mon Sep 04, 2017 9:36 pm Up
Hello,
I don't post often,but I always get good info when I do Smile
doing a service today as its been slightly missing once in a while nothing major.decided to do plugs,and noticed in No.1 (furthest from cam belt) there was about 1/4 of a teaspoon of oil in the plug hole,,the plugs are not fouled and all 4 are burnt lovely on the ends,i've had the car since new and 40 k on the clock.
I checked the rocker cover gasket and the oil breather pipe (runs directly above) and seems ok.
is there any other way this oil can reach the top part of the plug?
seems strange as the coil pack has a rubber cover when fitted to stop anything getting down
So my guess is there is a seal maybe in the head?
Thanks for any help,appreciate your time.
1.4lx 206
PostPosted: Tue Sep 05, 2017 8:36 am Up
Liners on the cylinder?
gazza82
PostPosted: Tue Sep 05, 2017 11:55 am Up
Over spill from topping up?
craggles
PostPosted: Tue Sep 05, 2017 11:17 pm Up
Hi,
Sorry for late reply.
I'm not sure what the cylinder liners are,but a internet search show something in the head.woyls they cause leaking from inside the head into the top part of the plug?
Defo not over spill from oil,if I did go over it would come forward due to the recess,but the cylinder the plugs fit in are raised slightly.,the oil is also old engine oil.not fresh.
Cheers for the replies so far.
1.4lx 206
PostPosted: Wed Sep 06, 2017 6:22 am Up
www.tpr.co.jp/tp_e/pro...about.html
