Online Now [248]:
Visitors: 247
Today: 6599
Total: 142628442
Forums › The Car › 206 Problems › what is this in the fuse box?
matty_hunt
PostPosted: Sat Sep 09, 2017 7:17 pm Up
Hi. I have a 55plate 206 1.4 hdi sw. It turns but will not fire. In engine fusebox, fuse 8 keeps blowing as soon as ignition is on. When wire plug between fuse 15 and 8 is removed, (first plug top left) fuse does not blow. I assume these wires lead to the faulty component. Anyone know what it feeds?
Many thanks
PostPosted: Sun Sep 10, 2017 6:34 pm Up
www.autogenius.info/pe...x-diagram/
Sounds like you need an auto electrician.
