Latest: tbafonso
Overall: 17130
Online Now [197]:
Visitors: 196
Today: 77050
Total: 103662814
Forums › The Car › 206 Problems › problem with 206RC code Error: p0012 sounds diesel
mini1275gt
PostPosted: Wed Sep 13, 2017 11:51 pm Up
Hi, i have a problem
the engine works fine but have some sound intermittent... sounds like the valves or diesel motor...
in Diagbox Scanner shows me this
p0553
p0141
p0012
i think the P0012 it's related with the sound (like a timing retarded)
please help me
PostPosted: Fri Sep 15, 2017 11:45 am Up
have you replaced the timing belt recently?
mini1275gt
PostPosted: Fri Sep 15, 2017 4:21 pm Up
yes mate
mini1275gt
PostPosted: Fri Sep 15, 2017 4:25 pm Up
could be the solenoid valve? 1920gr
www.yiparts.com/Files/...e0ee36.jpg
PostPosted: Fri Sep 15, 2017 4:38 pm Up
If you've had the belt done, then could be the usual 180/RC issue that the exhaust cams jumped a tooth or two.
mini1275gt
PostPosted: Fri Sep 15, 2017 4:59 pm Up
but the sounds diesel is not constant... what do you think?
Sim
PostPosted: Sun Sep 17, 2017 2:29 pm Up
The culprit is the P0012 fault:
"A" Camshaft Position - Timing Over-Retarded (Bank 1)
I have me old Jag spitting out this together with the P0011 (over-advanced), and has this rattling "diesel" noise after a lengthier run on a motorway, also "hunting" on cold idle.
In the best case, it's the sludge that's clogged up your VVT oil pathways, so a careful engine oil flush (as it's an older engine) and oil replacement is in order. Some other (less lucky) causes been mentioned already in this thread and also in e.g. www.youtube.com/watch?v=W-NuqnhPu-8 and a TSB for Fords (an S-Type is a Mondeo after all..:)
I've found a remedy temporarily that the rattling can be silenced by switching the engine off, then back on, and then sharply revving it once (or just start driving). Note that rattling stays if you don't switch engine off/on before (to do with oil pressure probably)
Good luck!
EV
Jag S(crapped)- & X-Type
GTC VXR (sold)
