Latest: Kifi69
Overall: 17183
Online Now [521]:
Visitors: 520
Today: 109644
Total: 144256659
Forums › The Car › 206 Problems › Can't lock car! My key fob is dead and keyholes are closed!
dearsistah
PostPosted: Fri Oct 20, 2017 8:53 am Up
Hello!
I'm in need of serious help! What happened is the key fob started glitching and deprogramming itself, so what I did was I changed the battery of my key, it worked for 3 weeks, now it doesn't work anymore, even after changing it, the key fob still managed to deprogram time after time, now after trying to reprogram everything multiple times, it still doesn't work. The second problem, which I want to solve is that my key holes in the doors are both blocked, when I bought the car they came like that, thus I can't lock my car in anyway. Here's how they look, I was in 3 different car repairs and they said they couldn't help and redirected me elsewhere. So I need your help! How do I remove the thing that is blocking my key hole? Can I just hit it off or what? I don't want to damage the car.
Please help, if possible!
I'm adding a picture of the keyhole.
PostPosted: Fri Oct 20, 2017 9:21 am Up
Looks like someone has replaced the key barrels with non working ones.
Just get a complete 2nd hand locked set of Ebay.
You need ignition, both door barrels & fuel filler cap at least, if you have boot / glove box locks fitted also get those to keep a matching lock set - the mechanical locks on a 206 are pretty simple to change.
What year of 206 is it as there are 2 completely different ways of resyncing the keyfob to the car after battery replacement depending on year of car.
