Latest: tbafonso
Overall: 17130
Online Now [197]:
Visitors: 196
Today: 17
Total: 103044835
Forums › The Car › 206 Talk › Retro iosfix kit?
Retro iosfix kit?
glenpring
PostPosted: Tue Nov 14, 2017 9:52 am Up
Been looking online and found iosfix can be retro fitted to fords volvos and a few more cars anyone know if it can be retrofitted to a 206? Also does anyone have iosfix in there 206 they can take a picture of the anchor points and post them so I can see what they look like in the 206. Thanks
PostPosted: Tue Nov 14, 2017 2:32 pm Up
A lot of 206 have factory fitted ISO FIX.
Most have it on the rear seats for each outer position.
Newer ones also have it on the front passenger seat.
On the rear seat, feel along the bottom edge of the back rest where it meets the base cushion, you should feel a small slit in the material - this is where the ISO FIX loops will be found.
On the front passenger seat, feel between the base cushion & back rest - you should feel the ISO FIX loops ( if fitted )
glenpring
PostPosted: Tue Nov 14, 2017 3:35 pm Up
No there is non fitted this is why I asked about retro fitting like some ford and Volvos allow
PostPosted: Tue Nov 14, 2017 4:33 pm Up
Fit an interior / seats from a newer 206 that has ISO FIX.
The ISO FIX loops are part of the seat frame.
Are you sure there not already there? as there very well hidden.
glenpring
PostPosted: Tue Nov 14, 2017 4:34 pm Up
no its a 05 plate 206 i have looked and i cant see them i know what they look like
PostPosted: Tue Nov 14, 2017 4:40 pm Up
Strange as I have a 03 & GF has a 53 plate & they both have ISO FIX front & rear fitted.
glenpring
PostPosted: Tue Nov 14, 2017 4:43 pm Up
Nothing there unless I’m totally missing something could you take a picture?
