Latest: Beduff1977
Overall: 17134
Online Now [2006]:
Visitors: 2005
Today: 206845
Total: 109773255
Forums › The Car › 206 Problems › Multifunction display backlight...
pjaysnowden
PostPosted: Fri Dec 08, 2017 3:14 pm Up
OK. So...the backlight on the clock/radio multifunction display had two blown bulbs. So I bought 3 new ones. 1.2 watt...12v. All good so far.
I replaced all three. Now none of them work. The display still shows the time and date....but it has no back light. I have checked both f4 and f15 fuses. Both not blown. Everything else in the car is fine. I used a meter to check the bulbs were houses correctly in the holders. Thanks in advance
klemen241
PostPosted: Fri Dec 08, 2017 7:22 pm Up
One needs to be turned other way. Not sure which one, i think middle one
PostPosted: Fri Dec 08, 2017 9:52 pm Up
Did you put the bulbs in when the power was on? I found that blows bulbs.
klemen241
PostPosted: Sat Dec 09, 2017 10:48 am Up
Hmm no, but i was turning them when they were on to find out the order
VorTechS
PostPosted: Tue Dec 12, 2017 10:59 pm Up
Staff - Vortechs
Is it possible you've broken the track connector to the bulbs? The soldering is very flimsy, and is a Common problem with the MFD.
I've got a PPT30 that's open and I can show you what I mean.
PostPosted: Thu Dec 14, 2017 2:48 pm Up
Will I would say that you didn't fit the bulb holder in it's correct position to make a good contact with the circuit board.
pjaysnowden
PostPosted: Fri Dec 22, 2017 11:42 am Up
It is none of the above things. Sorry so long to reply. I didn't get notification of replies. All soldering is fine....as tested with a meter for continuity. I also connected the bare bulb board directly to a 12v supply in my workshop. The bulbs all lit up. So..the bulbs are connected correctly.
gazza82
PostPosted: Fri Dec 22, 2017 5:11 pm Up
You using bulbs or LED's? LED's only work in one way (polarity specific)
