Latest: tebas93089
Overall: 17179
Online Now [95]:
Visitors: 94
Today: 19158
Total: 137984703
Forums › The Car › 206 Problems › Stop warning light & noisy fan
UserError
PostPosted: Sun Feb 18, 2018 4:17 pm Up
Hi,
I'm on a steep 206 learning curve as my son recently bought one and my elderly neighbour has just got a 2001 1.1 206.
Unfortunately literally on getting it home (private sale), the "Stop" warning light comes on. There are no other warning lights lit.
I have a cheap OBD reader which I plugged in but it gave no codes through Torque Lite
Also, when left to idle when the cooling fan comes on it makes a bit of a racket - a low-pitched shriek - possibly dry bearing type noise and it sounds like the fan blades are catching the casing or similar.
The temperature stays rock solid & the fan cuts in & out nicely.
Could these be related?
Any help much appreciated.
PostPosted: Sun Feb 18, 2018 5:08 pm Up
Is the STOP light on or flashing?
2001 - is it multiplexed? see link as it explains how.
206info.co.uk/Forums/v...=1675.html
As for the fan, the motor & fan is easily replaced once both parts of the front grill is removed - get new grill clips as they usually break.
Make sure you get the correct fan motor as there are a few different connector plug used depending on age / spec of 206.
