Latest: ArtistKS
Overall: 17145
Online Now [54]:
Visitors: 53
Today: 16547
Total: 116050299
Forums › The Car › 206 Problems › peugeot 206cc issues please can anyone help
annie4567
PostPosted: Sun May 06, 2018 2:15 pm Up
Hi wondering if anyone can help as i am literally at the end with this car!!!
right had the car a matter of weeks car has recently started overheating but think we have foud the problem as thre fan isnt kicking in when suppose to
but have a more pressing issue of when the weather gets warm outside (even if it not overheating ) nit cuts out and loses power not only when idoling but also when driving, i put my foot on accelorator and it doesnt rev just cuts out, the revs when it does start back up are in my eyes very high as trying to get it to 30mph u are at 2500 revs or higher. this problem only seems to occur when the weather gets warm its like something is sticking
does anyone have or hadfd any issues like this before and has it ever been fixed.
#listed below is everything i have had done in a matter of weeks:
clutch
cambelt
crank position sensor
engine coolant sensor
been on diagnostics 4 times and all the codes have had rectified by sensors etc
please please any help at all
PostPosted: Sun May 06, 2018 3:17 pm Up
The wiring loom for the cooling fan is a known weak spot on the 206 & rots out.
Which engine is fitted as the 206 CC has been available with several different petrol & diesel engine options.
Fingers crossed it's not the 1.6 Diesel engine.
annie4567
PostPosted: Sun May 06, 2018 3:38 pm Up
1.6 16v petrol x
annie4567
PostPosted: Sun May 06, 2018 3:41 pm Up
Forgot to say the overheating has now been cured with a new radiator fan switch thing
Rubyoptics
PostPosted: Mon May 07, 2018 3:39 pm Up
I bought my 2.0 cc just before Christmas and had trouble with a high and unstable idle. Looking at various threads on here suggested the sparkplugs as the cause as the coilpack is known to dislike ngk sparkplugs. This is a problem as ngk have a reputation for being high quality so many people fit them. I bought some Bosch quadspark and sure enough when fitting them found ngk plugs had been fitted. Had no problems since then.
PostPosted: Mon May 07, 2018 6:02 pm Up
NGK spark plugs are high quality - it's just the phase detection system that detects misfires can get upset when NGKs are fitted.
annie4567
PostPosted: Mon May 07, 2018 6:05 pm Up
It has NGK spark plugs in now, so maybe change them back to Bosch ones?
Would these issues occur when it’s cold or hot or both as at present it’s only cutting out when it’s hot!! Very bizarre
Am completely puzzled
Rubyoptics
PostPosted: Mon May 07, 2018 8:38 pm Up
Sorry, I didn't mean to imply that ngk weren't high quality, rather that because they ARE high quality people fit them unaware of the issues they can cause. I don't know if it will solve your problem Annie, but for a tenner I reckon it's worth a shot.
gazza82
PostPosted: Tue May 08, 2018 3:37 pm Up
We lost power when the car was warm .. but it was intermittent. Always started first time.
I swapped out the coil pack (not sure of make) and plugs for Bosch Super-4s .. as I don't think the had even been changed (they had Peugeot logos!). After that, no problems .. well not with losing power .. plenty of other "fun" things with a 206!
annie4567
PostPosted: Tue May 08, 2018 3:46 pm Up
I have had the code read today again for the 6th time and it has come up with throttle position sensor so I am replacing the whole throttle housing and sensor at a very tidy sum of money. It has now shown up anti pollution fault and for the first time ever the engine management light has come on
annie4567
PostPosted: Tue May 08, 2018 3:48 pm Up
Gazza82 this sounds very much like what my stupid 206 is doing it’s only when the car gets warm it starts losing power. I am most definitely gonna replace plugs just need to know what’s the best coil pack to use should I go to peugeot?
PostPosted: Tue May 08, 2018 6:10 pm Up
Start with the plugs, dont worry about the coil pack yet!
annie4567
PostPosted: Tue May 08, 2018 6:12 pm Up
Got the Bosch super 4 plugs my dad is fitting them tomoz night
Rubyoptics
PostPosted: Tue May 08, 2018 7:01 pm Up
Let us know how you get on. I agree with Gazza that it could also be a coil pack problem, but the NGK plugs could be presenting the same issues. As the plugs are cheaper, I suggested starting there as it removes the potential for other problems down the road. Fingers crossed the plugs fix the initial problem you came here with anyway!
gazza82
PostPosted: Wed May 09, 2018 7:27 am Up
I think all the coil packs would be OK with Bosch plugs as the issue is when you combine one brand with NGK.
Change the plugs, see if it improves then worry about the coil pack.
HINT: if you have an issue on a car only change ONE thing at a time ..
1) if you go out and swap a lot of parts at once you won't know what fixed it
2) you have probably brought parts you didn't need
