Online Now [628]:
Visitors: 626
Members: 1
Today: 10153
Total: 106204385
Forums › The Car › 206 Problems › Rear Bumper Fasteners
quietly_myself
PostPosted: Tue Jun 05, 2018 11:11 am Up
Does anyone know what fasteners are used to fit a rear bumper? I’ve got several missing or damaged and want to buy new ones before I try removing the (few) remaining.
2006 1.6 HDi Sport (though I assume they’re the same on all models).
There should be:
3 along the top edge of the bumper (attach to the car body)
2 above the wheel arches (1 either side - attach to the car body)
2 underneath the mud guards (attach to the mud guards)
2 underneath the back (attach to the underside of the car)
Also, any suggestions on the best place to buy?
gazza82
PostPosted: Tue Jun 05, 2018 11:23 am Up
I think they are special hex bolts so try a Peugeot dealer to start with .. or ebay!
PostPosted: Tue Jun 05, 2018 12:00 pm Up
The ones bolting to the rear quarters are just 10mm nuts on funky square headed bolts.
gazza82
PostPosted: Tue Jun 05, 2018 3:37 pm Up
This might help ... shows the part numbers so you can trace them ...
Bog standard bumper but the others should use the same fittings.
quietly_myself
PostPosted: Tue Jun 05, 2018 3:53 pm Up
Thanks gazza, that’s brilliant.
gazza82
PostPosted: Tue Jun 05, 2018 7:55 pm Up
Had that saved on my laptop from when I needed front ones when I replaced the bumper ...
quietly_myself
PostPosted: Wed Jun 06, 2018 6:05 am Up
I went ahead and bought the fixing kit (6999 H0). Less than £7 - keeps things simple
