Latest: cogeim7
Overall: 17185
Online Now [418]:
Visitors: 417
Today: 13395
Total: 147331455
Forums › The Car › 206 Problems › Hatchback 2A/C 1.6l Belt problem.
RandomRoss
PostPosted: Fri Nov 23, 2018 5:07 am Up
Hi All,
Hoping to get a little help, Just got my first car, details below>
Peugeot 206 Hatchback 2A/C 1.6l 4cyl
MAR 2005
VIN VF32ANFUR44614611
Air Conditioning and Power Steering
Drive belt screaming, have replaced Drive belt with 6PK1575
Replaced Idler pulley
Replaced Belt Tensioner Serpentine Belt DAYCO APV2547
I can’t find the diagram for the serpentine belt for the 1.6l. All I can find is the 1.4l & 2.0l. My configuration does not match either. I’m at a loss Confused
I have linked a pic to describe why i'm perplexed!
Please help
Thank you in advance!
Regards
RR.
Sim
PostPosted: Fri Nov 23, 2018 7:46 pm Up
Hello there TU5JP4 friend,
Autodata gives this routing for your full fat setup (I can't look up on mines as it currently has electronic PAS conversion):
This is the tensioner layout and part numbers for your 1.6 16v (you can see the length of the belt is 1560mm):
Good luck with the squealy pig problem and keep us posted!
EV (roadtripper)
Jag S(crapped)- & X-Type
GTC VXR (sold)
RandomRoss
PostPosted: Sat Nov 24, 2018 3:43 am Up
Wow! Sim thank you sooo much!
You have helped me enormously, I think who ever had fixed this car previously had followed a lot of other 3rd part sites and parts distributors, which list the 1575mm belt!
Replaced the idler pulley and tensioner assembly - new belt at 1560mm!
No longer a squealy pig, but purring lion!
I will get myself organised will pics and details now I know about this forum
Again thank you for your help
