Latest: Kifi69
Overall: 17183
Online Now [1439]:
Visitors: 1438
Today: 3868
Total: 144463714
Forums › The Car › 206 Problems › 1.4 HDI Oil light on
Jamerz
PostPosted: Thu Dec 13, 2018 3:16 pm Up
Hey guys,
A mate has a 1.4 Hdi that cut out and wouldn't start
it was then driven with no issue to a parking spot
now when started it will start perfectly but then after 10 seconds the oil lamp comes on, the engine continues to run
Hes worried to drive it just in case there's something wrong?
Just wondering if there could be any common issues anyone knows about?
Many thanks
1.1 206 LX, Tivoli Blue
gazza82
PostPosted: Thu Dec 13, 2018 7:57 pm Up
Low oil? Faulty oil pressure or level sensor(s)?
Checked the oil level with the dipstick (when engine is cold)?
Jamerz
PostPosted: Tue Dec 18, 2018 5:00 pm Up
the oil was at the correct level hot or cold
an oil change has just been carried out and the dash light doesn't come on anymore, allegedly there were some metal particles on the magnetic sump plug.
potentially the oil hasn't been changed for 2 intervals thanks to a non trustworthy garage
engine still seems to pull well?
didn't realise engine oil plugs were magnetic, is this bs?
gazza82
PostPosted: Tue Dec 18, 2018 10:48 pm Up
BS ... mine isn't and it's the original.
VorTechS
PostPosted: Wed Dec 19, 2018 8:16 am Up
Staff - Vortechs
My 1.6 had a magnetic plug, but it wasn't necessarily an OEM one.
gazza82
PostPosted: Wed Dec 19, 2018 10:32 am Up
Don't forget the 1.4Hdi is a different engine .. shared with Ford and others .. some engines may have a magnetic sump plug, most don't!
I've had my 1.4 HDI since it was 1 year old and it had a new engine in the first year (Warranty! Head gasket failed on the first owner after only 300 miles!). I've never had the sump plug replaced.
Jamerz
PostPosted: Wed Dec 19, 2018 3:17 pm Up
Very Interesting, the vehicle is running well now.
It has almost 190k on the clock, though saying that we used to have an 04 plate HDI that had around 325k and was only scrapped because of a knackered back axle and cambelt due. So hopefully the engine isn't about to brick it.
I will be cautious of this garage however at least they actually change the oil when asked too!
thanks guys have a good Christmas!
PostPosted: Sun Dec 23, 2018 9:03 pm Up
Usually a faulty or bad oil filter can cause the oil light to come on.
