Online Now [227]:
Visitors: 226
Today: 12660
Total: 143002780
Forums › The Car › 206 Problems › Electrical issue?
Electrical issue?
Djpj
PostPosted: Thu Dec 20, 2018 4:56 pm Up
Hi. 2008 206 1.4 petrol.
Was on my way home today and car just cut out. Restarted it but did it again a min later. Now it wont start at all. Engine turns over but wont fire up. so im guessing i have power to the starter motor so cant be the battery. Instument panel is dead. No wipers or anything. Checked all the fuses but look ok. Any help would be grate
gazza82
PostPosted: Fri Dec 21, 2018 9:10 am Up
All the fuses? In engine bay and under the dash?
PostPosted: Sun Dec 23, 2018 6:19 pm Up
Check the earth points as well
Jamerz
PostPosted: Sun Dec 23, 2018 8:56 pm Up
Is the Airbag light on?
1.1 206 LX, Tivoli Blue
PostPosted: Sun Dec 23, 2018 9:07 pm Up
A faulty ignition coil goes bad with the 1.4 engine.
PostPosted: Wed Dec 26, 2018 7:48 pm Up
try to jump start the car and see what will happen,as I suspect that your battery is faulty.
