Online Now [1376]:
Visitors: 1375
Today: 197920
Total: 148955198
Forums › The Car › Solved 206 Problems › Unlocks itself
Unlocks itself
Forum Index › Solved 206 Problems
Griggsy
PostPosted: Sun Mar 28, 2010 3:46 pm Up
Recently i had a problem with locking the car. To start with the locks would bounce twice and on the third attempt lock however when i returned to the car a while later it was unlocked. My car will lock now but randomly unlocks itslef! This is a big problem as i know its locked when i leave it however when i return its unlocked itself!!!!!!!
please somebody any ideas?
Whats up?
coopskin
PostPosted: Sun Mar 28, 2010 3:48 pm Up
Trade Rating: +13
the locking solenoids on the doors or boot need replacing mate
Griggsy
PostPosted: Sun Mar 28, 2010 4:48 pm Up
Thanks, would that cause it to unlock randomly...sometimes days apart?
Thanks!
Whats up?
Dillon
PostPosted: Sun Mar 28, 2010 4:51 pm Up
Staff - Dillon
Yep, Turned out to be the drivers door soleniod on mine locks would bounce car randomly unlocked itself. It will only get worse get it in and changed asap!
Griggsy
PostPosted: Mon Mar 29, 2010 4:58 am Up
Thanks for the reply... just as a sort of heads up - how much did it cost you?
Whats up?
kit325
PostPosted: Mon Mar 29, 2010 5:51 pm Up
Try to identify the side which is malfunction. Try to spray some wd-40 into the lock MECHANISM first, it might solve your probelm if your lucky. If still not working you will need to replace the door lock MECHANISM.
cgi.ebay.co.uk/PEUGEOT...27b0188b3b
It shlould be half an hour job taking the door panel then replace the lock MECHANISM. Had the same problem with my 206, problem solved since i replace the lock.
kit
pug206lx
PostPosted: Mon Mar 29, 2010 5:55 pm Up
ive seen this on other cars. You lock it, locks. Come back in the morning and all the doors are open!
Definitely the solenoid. probably about £10 for a solenoid from a scrappy and you can fit it yourself
coops180
PostPosted: Mon Mar 29, 2010 6:13 pm Up
these solenoids are 60£ a side from pug i have fitted quite a few
2003 206gti180 coops.21 @ hotmail.co.uk
Griggsy
PostPosted: Tue Mar 30, 2010 5:49 am Up
Thanks for all you help guys, I appreciate it! Also thanks for the link and for the description and it looks like I can save myself a small fortune by doing it myself.
Cheers!
Whats up?
Griggsy
PostPosted: Thu Apr 01, 2010 8:20 am Up
Just thought I would let you guys know how i got on....
After accidently slamming the door the other day it has stopped bouncing when i try to lock even though it was stilling randomly unlocking.
It has been a couple of days now and it doesn't bounce and I haven't found its unlocked itself so It seems like it might have sorted itself! I just hope that if it does unlock itself I will find it and not someone else...
thanks anyway
Whats up?
pug150
PostPosted: Thu Apr 01, 2010 8:26 am Up
my old gti used to do this when i hadnt used it and the battery was a bit flat just a thought
Griggsy
PostPosted: Thu Apr 01, 2010 11:30 am Up
I thought that aswell but I charged the battery about a month ago as it was flat so now i'm not sure.
Whats up?
