Online Now [605]:
Visitors: 604
Today: 112544
Total: 146815115
Forums › The Car › 206 Problems › 206 working temperature
Dunc01977
PostPosted: Mon Sep 16, 2019 6:01 pm Up
Hi there, over the last 2 days my 206 1.1 has started to run cooler, it usually sits happily around the 90 degrees Mark but now will hardly get above 80, tophose is red hot, any ideas what could be the problem? Don't want a head gasket problem.
PostPosted: Tue Sep 17, 2019 7:01 am Up
If its running cooler I would suspect the thermostat is stuck open so not allowing the engine to get up to the correct operating temperature.
TU1 thermostat is a simple job to replace, might as well fit a new coolant temp sensor at same time ( check what colour the sensor connector is before ordering! )
