Online Now [142]:
Visitors: 141
Today: 74025
Total: 105402466
Forums › The Car › 206 Problems › Peugeot 206 immobiliser
desbarron
PostPosted: Thu Sep 12, 2019 9:22 pm Up
Intermittent starting which i think is immobiliser related. Occassionsl every two or three days the car wont start. When it does its instantaneous like a new car. When it doesnt the engine rotates but doesnt start. Ideas Mad please.
gazza82
PostPosted: Fri Sep 13, 2019 7:44 am Up
Needs to be put on a diagnostic to see if any codes are being recorded to show you why
desbarron
PostPosted: Fri Sep 13, 2019 11:15 am Up
No faults shown
gazza82
PostPosted: Fri Sep 13, 2019 6:11 pm Up
Depends if you are using a PSA compatible dignostic. PP2000 is best
What year/engine?
desbarron
PostPosted: Sat Sep 14, 2019 4:16 pm Up
PostPosted: Sun Sep 15, 2019 3:20 pm Up
Petrol / diesel?
8 or 16 valve?
desbarron
PostPosted: Mon Sep 16, 2019 4:14 pm Up
Petrol 16
PostPosted: Tue Sep 17, 2019 7:06 am Up
This will have the electronic fly by wire throttle system fitted then.
The electronic throttle body controls the idle speed & the throttle body is a known weak spot.
When it doesn't start switch the ignition OFF & then open the door, if it beeps then its not the immobiliser.
Have you scanned if with Peugeot Planet as this engine management system can store fault codes for the electronic throttle system but not put the diagnostic warning light on.
desbarron
PostPosted: Tue Sep 17, 2019 8:46 am Up
Manual throttle but I will clean the valve.
Bleep test passed
PostPosted: Wed Sep 18, 2019 7:40 am Up
You got the VIN number?
desbarron
PostPosted: Wed Sep 18, 2019 1:32 pm Up
Vf32ckfwf44155541
PostPosted: Sat Sep 21, 2019 8:43 am Up
Old fashioned mechanical throttle set up on this one according to Service Box
desbarron
PostPosted: Sat Sep 21, 2019 4:57 pm Up
Well I know that, it doesn't help diagnosing the problem.
