Posted: Thu Sep 12, 2019 9:22 pm |
Intermittent starting which i think is immobiliser related. Occassionsl every two or three days the car wont start. When it does its instantaneous like a new car. When it doesnt the engine rotates but doesnt start. Ideas please.
Posted: Fri Sep 13, 2019 7:44 am |
Needs to be put on a diagnostic to see if any codes are being recorded to show you why
Posted: Fri Sep 13, 2019 11:15 am |
No faults shown
Posted: Fri Sep 13, 2019 6:11 pm |
Depends if you are using a PSA compatible dignostic. PP2000 is best
What year/engine?
Posted: Sat Sep 14, 2019 4:16 pm |
Posted: Sun Sep 15, 2019 3:20 pm |
Petrol / diesel?
8 or 16 valve?
Posted: Mon Sep 16, 2019 4:14 pm |
Petrol 16
Posted: Tue Sep 17, 2019 7:06 am |
This will have the electronic fly by wire throttle system fitted then.
The electronic throttle body controls the idle speed & the throttle body is a known weak spot.
When it doesn't start switch the ignition OFF & then open the door, if it beeps then its not the immobiliser.
Have you scanned if with Peugeot Planet as this engine management system can store fault codes for the electronic throttle system but not put the diagnostic warning light on.
Posted: Tue Sep 17, 2019 8:46 am |
Manual throttle but I will clean the valve.
Bleep test passed
Posted: Wed Sep 18, 2019 7:40 am |
You got the VIN number?
Posted: Wed Sep 18, 2019 1:32 pm |
Vf32ckfwf44155541
Posted: Sat Sep 21, 2019 8:43 am |
Old fashioned mechanical throttle set up on this one according to Service Box
Posted: Sat Sep 21, 2019 4:57 pm |
Well I know that, it doesn't help diagnosing the problem.
