Online Now [616]:
Visitors: 615
Today: 32026
Total: 105074357
Forums › The Car › 206 Problems › 206 cc electric window gremlins
Mouth2020
PostPosted: Tue Jan 21, 2020 3:56 pm Up
I’ve just bought a 2006 Peugeot 206 with an electric hard top. It has a few issues which I’m working through, I the roof wasn’t working but this turned out to be a faulty micro switch on the drivers side.
The issue I’m having right now is weird, the window switches weren’t working properly in that the passengers side worked fine and the drivers side did nothing. There was also a spare new looking switch supplied with the car.
When I put the new switch in, both windows will go up (the switch markings are opposite to the one that was in the car) but the switches operate backward ie pushing the switch down raises the window and pulling lowers. Also with this switch connected when the ignition is first turned on all windows lower!
The original switch I took apart to inspect and found carbon on one of the contacts, I cleaned the contact but it is quite damaged. Now putting that switch in again the passengers side works fine as it was doing and the drivers side will go down no matter which way the switch is pulled/pushed.
Have I got 2 dodgy switches or is there something I’m missing here like the window needs setting up electronically or something?
Cheers for any help you can give!
ekjdm14
PostPosted: Wed Jan 22, 2020 11:58 am Up
Sounds like you may have 2 dodgy switches, but the second unit being more consistent I'd run with that for the moment & try a BSI reset (will try find the link on how to do that) as a confused BSI can cause issues like upside down windows.
Only other thing I'm not 100% on is if there's any difference between multiplex/pre-plexed switches (probably) which might explain things too.
Whereabouts are you located? I have a known good switch for testing purposes if you get round Congleton at all?
+'99 306 2.0SE cabriolet
+'97 306 1.9LXDT
French Car Forums
Mouth2020
PostPosted: Sat Jan 25, 2020 1:50 pm Up
Thanks, I re stripped down the older looking switch with the burnt contact and rebuilt the contact pad on the circuit board and its working fine now. On to the next issue to figure out! Thanks again
ekjdm14
PostPosted: Sat Jan 25, 2020 6:04 pm Up
Good stuff, hope the next job is a simple cheap fix too. If nothing else they keep you out of trouble, these cars lol
+'97 306 1.9LXDT
French Car Forums
