Online Now [1096]:
Visitors: 1095
Today: 246408
Total: 149310587
Forums › The Car › 206 Talk › Peugeot 206 2.0 HDI Sport
Forum Index › 206 Talk
CT206
PostPosted: Fri Apr 10, 2020 3:29 pm Up
Hi there,
My mother's partner is giving me a 206 HDI Sport 2.0 as I currently have a clapped out Astra and no funds to buy a new car ha.
Just curious as to whether this car has any aux/mp3/BT function?
My Astra has a built in aux.
Thanks in advance.
PostPosted: Fri Apr 10, 2020 3:51 pm Up
No it wont have any aux / bluetooth / mp3 features from the factory.
You can add a aux in to the cd changer port on the back of the factory radio BUT it would need to be activated by Peugeot Planet before it would work.
Other option is replace the head unit with something suitable which is likely to be the best way to go.
CT206
PostPosted: Fri Apr 10, 2020 4:59 pm Up
What is Peugeot Planet? And does it cost?
PostPosted: Fri Apr 10, 2020 6:36 pm Up
Peugeot Planet is the diagnostic software required to adjust / diagnose Peugeot products.
Software can be found free online but the Lexia interface costs £
CT206
PostPosted: Fri Apr 10, 2020 7:28 pm Up
So in your opinion would it be cheaper just to stick a CD player with aix/MP3/BT in there?
PostPosted: Fri Apr 10, 2020 8:16 pm Up
Yes - you could also try & get one that interfaces with the remote audio stalk.
gazza82
PostPosted: Fri Apr 10, 2020 9:26 pm Up
If it's a multiplex car (the radio does not have a display ... it uses the multi-function display you will need PP to tell the car it no longer has a standard radio ... or it bleeps at you ...
An older 206 can be swapped easily ... plug & play cable adaptors .. I fitted a Sony unit to my daughter's CC very quickly and that had aux and usb ... maybe no bt but that was few years ago. you'll need a dash adapter if the older style too
PostPosted: Sat Apr 11, 2020 8:16 am Up
I've never know a multiplex 206 beep just by removing the factory radio.
CT206
PostPosted: Sat Apr 11, 2020 8:50 am Up
My sister had a 1.1 206 Style. That used to beep at me. That was a 52 plate. Mines an 05
gazza82
PostPosted: Sat Apr 11, 2020 9:38 pm Up
My 2002 did when I removed it to try and work out why the new rear speakers didn't work (Style only had fronts).
Put the radio back and bleeps stopped. Tried a non-Pug one (borrowed so temporary) and rear speakers worked, but bleeping came back!
Got a copy of PP2000, put Pug radio back and discovered you had to program BSI to use rear speakers!!! And also found a setting to tell BSI oem radio wasn't fitted.
Sim
PostPosted: Tue Apr 14, 2020 8:56 am Up
I've fitted Connects2 AUX kit (CTVPGX010) to 2007 206 CC which did not have a CD changer, and did not have to change anything via PP2000.
The Bluetooth AUX kit (CTAPGBT010) also worked without problems in a GTi 180 (2004), where previously there was a CD changer fitted.
Again, nothing had to be altered via PP2000. Maybe just gotten lucky Smile
These kits work a treat, integrate with your steering wheel controls, and it's much better to listen to music via Bluetooth as opposed to AUX, as you can change tracks and playback pauses when you are having a phonecall or switch engine off.
The only downside of the BT handsfree kit is that you cannot do an outgoing call without using your phone, so that means stopping and engine off to do that Wink
EV (roadtripper)
Jag S(crapped)- & X-Type
GTC VXR (sold)
PostPosted: Wed Apr 15, 2020 2:56 pm Up
MrBSI, as if you are still on here?! Laughing
PostPosted: Thu Apr 16, 2020 6:53 am Up
I drop in here from time to time.
VorTechS
PostPosted: Mon Apr 27, 2020 2:09 pm Up
Staff - Vortechs
There is no MrBSI. It's just a cleverly crafted AI bot, everyone knows that.
PostPosted: Tue Apr 28, 2020 11:06 am Up
I agree!
