Latest: KevinRC
Overall: 17137
Online Now [169]:
Visitors: 168
Today: 106183
Total: 111140614
Forums › The Car › 206 Problems › Intermittently overheating then quickly returning to normal.
Cornallster
PostPosted: Thu Jul 02, 2020 6:38 pm Up
Hi,
I have a 1.4l Petrol 206 S (2005). I have an intermittent issue where the temp gauge will randomly go from roughly 90 to max within a few seconds causing the stop light to flash and beep. After a few seconds though the temperature will return to normal. I have a video of this happening at this link.
youtu.be/1jJMpJRpvgQ
It seems to happen in all sorts of situations. On some journeys it won’t happen at all whereas on others it will happen 4-5 times. There is plenty of coolant and the fan is working (it comes on when this happens). It doesn’t seem to have any pattern as it happens on journeys of different lengths and in different weathers.
The car is otherwise operating fine. I did recently have to replace the silencer (exhaust) however I don’t expect that to be relevant.
Thanks in advance for any help you can provide.
ekjdm14
PostPosted: Thu Jul 02, 2020 9:39 pm Up
I've recently learned that when the coolant temp sensor (CTS) is disconnected, the car defaults to fans on/overheat warning.
Check the connection to the CTS on the side of the head, if the wiring and connector are all in good shape then it's possible the sensor itself is failing and intermittently going open circuit.
+'99 306 2.0SE cabriolet
+'97 306 1.9LXDT
French Car Forums
gazza82
PostPosted: Fri Jul 03, 2020 7:25 am Up
Was the sensor on the thermostat housing when that happened on my 1.4 Hdi
