Online Now [104]:
Visitors: 103
Today: 97467
Total: 139847868
Forums › The Car › 206 Talk › 4 bulb multifunction display refurb
Curlycurly69
PostPosted: Sun Feb 14, 2021 5:02 pm Up
Hi,does anyone know of any where that would refurb my 4 bulb multifunction display unit out of my 2001 206 Gti.Thanks in advance.
gazza82
PostPosted: Sun Feb 21, 2021 9:47 am Up
Google threw up this ... www.actronics.co.uk/display ... although you may need to find a garage to act for you as they don't deal with the general public it seems ...
What's the problem with yours?
Curlycurly69
PostPosted: Sun Feb 21, 2021 7:08 pm Up
Hi Gazza,thanks for that.My one isn’t lighting up,I’ve changed all the bulbs but still nothing,I was told that there is a 3 or 4 pin white plug that the solder dries out on,I’ve had a look and it does look/feel loose.I did get the soldering iron out but it looks like a bit too fiddly for my level of soldering skills.In certain light you can see that all the pixels are still working.I need it because my blaupunkt 2040 has locked so I need to put the code in.
gazza82
PostPosted: Mon Feb 22, 2021 6:39 pm Up
on ours it was the pins that join the two circuit boards .. just had to warm the solder to let it reflow ..
Curlycurly69
PostPosted: Mon Feb 22, 2021 7:33 pm Up
Thanks for your help Gazza,I’ll have another look at the weekend.
