Latest: tbafonso
Overall: 17130
Online Now [61]:
Visitors: 61
Today: 62877
Total: 102906674
Forums › The Car › 206 Problems › Under car wiring on Gti.
Curlycurly69
PostPosted: Sun Feb 28, 2021 9:25 am Up
Hi,I need to pick peoples brains,does anyone know what electrical cable is in the conduit that runs next to the brake pipes from the engine bay to the rear on the passenger side on my 2001 206 Gti.The conduit has dropped from its clip and worn through.Thanks for any help.
PostPosted: Sun Feb 28, 2021 7:14 pm Up
Rear ABS wiring I do believe.
Curlycurly69
PostPosted: Mon Mar 01, 2021 7:31 pm Up
Thanks Edward.Need to reconnect it as it dropped from its clips and wore through on the tarmac.Would you know which wire to use?
