Latest: cogeim7
Overall: 17185
Online Now [468]:
Visitors: 467
Today: 195153
Total: 147475709
Forums › The Car › 206 Problems › 206 cc 1.6 auto fan not working
Craig2222
PostPosted: Thu Jul 15, 2021 9:49 am Up
Hi, car has been sat for 6 months, started to overheat and I noticed the fan wasn't working. I checked coolant and it was dirty brown so I drained and put fresh water in. I have taken it to a garage, they have tried replacing the relay but that hasn't worked. They are now waiting for an auto electrician to have a look. Should they find the problem or is it a case of trying a different part each time ?
Richardf
PostPosted: Fri Jul 16, 2021 6:37 am Up
I had the same fault. The problem turned out to be a common one where the relays in front of the coolant radiator, and just to the side, corrode at their terminals. So bad that some of the wires were disconnected. Went to a scrappy and found decent relays. I cleaned the terminals up then fitted new terminals to the wiring and all was good.
As an aside, if you have aircon, switching it on automatically turns one of the coolant radiator fans on (bypasses all the relays at fault), thus avoiding overheating until you fix the relays.
Hope this helps.
Richard
Southampton
Richard
Craig2222
PostPosted: Tue Jul 20, 2021 10:18 am Up
Thanks Richard. Fan kicks in now but not until about 105 degrees, is this normal ?
Richardf
PostPosted: Tue Jul 20, 2021 12:39 pm Up
Hi Craig, I'm unsure about temp to make the fan kick in. What does your dashboard temp gauge show? If it's gone passed the halfway point it may be worth just replacing the coolant thermostat.
By the way mate, it's handy to type your model, engine type, cc, etc as that then narrows any searching for answers/remedies. Good luck and keep us in the picture.
Richard
Southampton
Richard
