Online Now [113]:
Visitors: 112
Today: 77285
Total: 139007650
Forums › The Car › 206 Problems › Peugeot RD3 radio fault and removal and replacement of same.
Douglas62
PostPosted: Sat Sep 18, 2021 6:52 pm Up
I took the RD3 radio out to empty it of coins which had been posted in the CD player slot. I did not disconnect the cables but did remove the fron plastic fascia but again did not remove any cables or connectors. No coin had gone into the CD player. I replaced the radio and tried to tuen it on but there was nothng. The MFD only showed the date. Prior to taking the radio out of its slot it had been working OK.
The vehicle is a Peugeot 206 "LOOK" from 2007. Any advice please ?
All the best everyone.
Douglas
2v50
PostPosted: Sun Sep 19, 2021 12:09 pm Up
This might sound rather daft - but as you've said you haven't removed the connectors' I'm going to assume you have not tried this - pull the radio back out, disconnect all connectors from the rear then reconnect them ( or, if you wish, just give them a good firm push to make sure they are seated correctly. I'd hazard a guess they've just come a little loose.
Hope I'm right and its just a simple thing like that !
Sim
PostPosted: Sat Sep 25, 2021 1:36 pm Up
I hope you were careful with the ribbon cable on the fascia, otherwise it might have gotten dislodged a bit to lose contact: www.youtube.com/watch?v=Za1l_pt9l3o
EV (roadtripper)
Jag S(crapped)- & X-Type
GTC VXR (sold)
