Latest: cogeim7
Overall: 17185
Online Now [441]:
Visitors: 440
Today: 58579
Total: 147574862
Forums › The Car › Solved 206 Problems › Rear Axle strip pictures and rebuild
Forum Index › Solved 206 Problems
vwaudi
PostPosted: Tue Feb 09, 2010 4:44 pm Up
I posted this on the last site, so here we go again
I had the usual 206 rear worn axle problem, so after much deliberation I decided t buy a good second hand axle and refurbish it myself.
So the axle was 60 pounds and the bearings about 72 pounds. All finished it cost me about 130 pounds and about 6 hrs of time.
Note you will need access to hydraulic press to push torsion bars out of the arms and to assemble the bearings. But this could be done with a set of pullers and a decent vice.
The problem
Striped
second hand axle striped
new bearings
hello
Mrs_Howey
PostPosted: Tue Feb 09, 2010 4:46 pm Up
images don't work Sad
Moonstone blue 206 1.4look
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre Very Happy
vwaudi
PostPosted: Tue Feb 09, 2010 4:48 pm Up
easy.......
they do now
hello
Mrs_Howey
PostPosted: Tue Feb 09, 2010 4:50 pm Up
That makes taking the rear axle apart look easy, what tools did you use?
pro race 1.2 White
Morettes
GTI wings
namgaj
PostPosted: Tue Feb 09, 2010 4:52 pm Up
BIGGGGGG hammers and a load of brute force i bet!
4.0 V8 S-Type Jaguar
vwaudi
PostPosted: Tue Feb 09, 2010 5:02 pm Up
nothing special usual stuff. However a press made life a lot easier
press looked something like this.
press
but I think you could do it with some pullers which look like this
pullers
hello
Mrs_Howey
PostPosted: Tue Feb 09, 2010 5:05 pm Up
Oh right i see, Very Happy
well its very useful thank you Very Happy
pro race 1.2 White
Morettes
GTI wings
Brian
PostPosted: Tue Feb 09, 2010 5:10 pm Up
Trade Rating: +31
The presses are around 140+ second hand on ebay Smile Even still it's quite a technical process, not that simple! I'll be paying someone to do the 309's one that's for sure.
Mrs_Howey
PostPosted: Tue Feb 09, 2010 5:12 pm Up
But you learn from trial and error Wink
pro race 1.2 White
Morettes
GTI wings
vwaudi
PostPosted: Thu May 05, 2011 12:55 pm Up
3000+ views it must have been useful thread to start
hello
PostPosted: Sat May 07, 2011 2:01 pm Up
stupid questions, how did you press the outer oil seal in? Laughing
PostPosted: Sat May 07, 2011 2:04 pm Up
They go in from either side
Tbh it aint a hard job, i did it with a sledge, a vice, small hammer, and chisel
It really is easy
PostPosted: Sat May 07, 2011 2:09 pm Up
It really is easy
because i end up with a busted rubber seal after i try to hammer it in Laughing
vwaudi
PostPosted: Mon May 09, 2011 2:59 pm Up
It really is easy
Just taped them in with a hammer, make sure the surfaces are free from crud
hello
PostPosted: Mon May 09, 2011 3:02 pm Up
vwaudi wrote:
It really is easy
Bit of P80 wheel or a wire wheel would do Smile
