Online Now [96]:
Visitors: 95
Today: 4707
Total: 143073230
Forums › The Car › Solved 206 Problems › wont start
wont start
aj12
PostPosted: Sun Apr 04, 2010 11:48 pm Up
hi there i have a 206 gt i took the batt off yesterday and now she wont start Sad any idea's.
many thanks
aj
steve_b
PostPosted: Mon Apr 05, 2010 12:48 am Up
do a search on here for a bsi reboot and go from there. when you say wont start will it crank over?....
I dont have a 206, I am a peugeot master tech with 15 years in the dealers but now self employed and im hear to offer help and free advice
PostPosted: Mon Apr 05, 2010 1:00 am Up
You need to put the battery back in! Razz
Laughing
How new is the battery, may have lost its charge.
Does the starter motor/engine crank at all?
PostPosted: Mon Apr 05, 2010 6:39 am Up
Are all the connections secure?
Does it do anything at all?
harvey
PostPosted: Mon Apr 05, 2010 6:52 am Up
is there a inuff power in the battery to pick up? does it crank? try a diffrent battery from another car or use some jump leads or use a bit of easy start
harv
busybee
PostPosted: Mon Apr 05, 2010 8:42 am Up
If the engine turns and does not start its the knock sensor thats at fault change it or give it a clean.
wanted spares for my 206
aj12
PostPosted: Sat Apr 10, 2010 3:08 pm Up
thank u guys 4 all your help only just readin them as ive been away i hit the crank sensor some how lol
206 gt
Rob2859
PostPosted: Sun Apr 11, 2010 6:24 am Up
does the starter motor turn faster than normal? if it does there is no compression
busybee
PostPosted: Wed Apr 14, 2010 4:37 pm Up
If The Crack sensor dirty it would not start anyway or if damaged
