Latest: tebas93089
Overall: 17179
Online Now [111]:
Visitors: 110
Today: 17200
Total: 137789402
Project sleeper
Go to page Previous  1, 2, 3 ... 27, 28, 29 ... 85, 86, 87  Next
spike_202
PostPosted: Sun Apr 04, 2010 4:46 am Up
Steve206 wrote:
What does your trip computer say now Edward/Spike, has there been any difference on fuel consumption?
Mine is pre-plexd so i havent got any fancy suff like that lol
**spike's project**
TEAM:+200bhp
Shodoku
PostPosted: Fri Apr 09, 2010 12:01 pm Up
Is that a strut-brace I see? Smile
PostPosted: Sat Apr 10, 2010 2:35 pm Up
Well it turns out Ecosse haven't fitted an air temp sensor. If 99% of all other companies feel the need to fit one then why don't Ecosse? If they were such an unimportant sensor then why would all TB and ECU kits come with an air temp sensor?
The green and white wire at the bottom of the picture is the one that should be connected to the temp sensor and it's not connected to anything.
Put it this way every standard car uses an air temp sensor so the ECU can adjust the fuelling to account for the decrease in air density with increased air temperature. For every 10 degree increase in temperature a 3% reduction in fuel is needed as warm air is less dense than cool air. Without any correction this will mean the car is running richer than is ideal in warm weather.
Will be interesting to see how the car performs on an MOT emissions test.
Ruffy_206
PostPosted: Sat Apr 10, 2010 2:39 pm Up
Custom - Gold Stars
uuummmm looks like a rushed job to me. im glad your happy with it again and the new edition is a good choice keep this one a minter.
PostPosted: Sat Apr 10, 2010 3:03 pm Up
Looking sweet mate!! 1 question though and I apologise for being slow haha, whatever happened to your 206 with the cyclones? Or is this the same car? Keep up the good work mate
PostPosted: Sat Apr 10, 2010 3:15 pm Up
It's never had any wheels on it other than the Nimrods in the picture.
PostPosted: Sat Apr 10, 2010 3:57 pm Up
Out of interest Edward, what are you doing with all tohhse wires out. Shame about the set up.
PostPosted: Sun Apr 11, 2010 12:44 am Up
What am I doing with those wires out? I'm looking to see if the wire that would go to an air temp sensor is actually connected to anything. Those loose unused wires are normally bundled together in insulation tape. I've just removed the tape.
spike_202
PostPosted: Sun Apr 11, 2010 6:25 am Up
is that your standard ecu under the omex??
mine has been completely replaced by the emerald is there a reason for the omex needing the standard ecu??
**spike's project**
TEAM:+200bhp
PostPosted: Sun Apr 11, 2010 9:44 am Up
The Omex just runs the engine. The original ECU is kept as it controls everything else from the dimmer on the interior light to the speedo.
You sure yours has been removed?
spike_202
PostPosted: Sun Apr 11, 2010 10:18 am Up
lol yer i think so, well i cant find it any were
**spike's project**
TEAM:+200bhp
t1mmy
PostPosted: Sun Apr 11, 2010 10:21 am Up
What made you think in the first place that they hadn't connected the wires?
PostPosted: Sun Apr 11, 2010 11:40 am Up
I couldn't find the temp sensor anywhere so I went looking for confirmation by checking the wiring. I got the manual from the OMEX website to check what each wire did on the connector block.
spike_202
PostPosted: Sun Apr 11, 2010 12:56 pm Up
was you not given a hard back copy??
i got lots of stuff with the k3 i got a comms lead,hand book,cd software,loads of stickers and a catalogue
**spike's project**
TEAM:+200bhp
PostPosted: Sun Apr 11, 2010 1:12 pm Up
You would have thought they could have insulated the connectors, and put better wire covering, ie OEM
That is for the price you paid Neutral
But then again, installing TB's isnt brain surgery, as the OMEX should supply a copy of how to install, so technically you could do everything apart from the mapping Confused
Page 28 of 87
