Latest: jackrox1992
Overall: 17186
Online Now [568]:
Visitors: 567
Today: 156145
Total: 148100010
Forums › The Car › Solved 206 Problems › How do I Pass A Wire From My rear view(!) Mirror to the boot
Forum Index › Solved 206 Problems
andre206
PostPosted: Mon Apr 12, 2010 1:31 pm Up
...through the head lining?
Now i know there is a small 'arch' in the head lining right above the wing mirror, but then im stuck. How can i get a wire into the lining all the way to the back of the car to come out in the boot, so that you cant see it in the car at all, just in the boot.
Thanks.
PostPosted: Mon Apr 12, 2010 1:37 pm Up
Run it thru the door, thru the grommet, down under the carpet and thru the c pillar would be the easiest way
andre206
PostPosted: Mon Apr 12, 2010 1:54 pm Up
so im guessing up into the headlining
along the head lining bordering the windscreen (?)
Down through....? Just not following here.
Thanks for your help
PostPosted: Mon Apr 12, 2010 1:57 pm Up
Take the door card off. You will then need to thread it thru the rubber grommet where the standard door loom is.
The wire should come out behind the fuse box-ish
Then go down, underneath the carpet, all the way to the back of the car.
What are you actually trying to do?
andre206
PostPosted: Mon Apr 12, 2010 2:00 pm Up
I've just purchased a Rear view mirror that has a parking sensor built into it, ill get pics up when im fitting it because i think it should be really interesting.
So that is why i was wondering how i was going to get the cables to the back of the car.
Sorry im not good at understanding, but why am i going into the door? Surely i can go down the pillar on my right side and then behind the fuse box like you suggested?
PostPosted: Mon Apr 12, 2010 2:02 pm Up
Your title says wing mirror not rear view mirror Laughing
Thats why i said you need to go thru the door Laughing
In that case, yeah just thread it thru the headlining and behind the rubbers on the door
andre206
PostPosted: Mon Apr 12, 2010 2:03 pm Up
S***! Lol! Sorry mate.
Thanks for your help!!
Andre Laughing
meady
Trade Rating: +45
people are ssying to the door because u stated that you have to get a cable to the wing mirror, i think you mean the rear view mirror mate
TEAM - I HATE FACEBOOK Smile
