Online Now [239]:
Visitors: 238
Today: 51796
Total: 142095253
Forums › The Car › 206 Talk › Cruise control
Cruise control
Go to page Previous  1, 2, 3 ... 29, 30, 31 ... 34, 35, 36  Next
HDiMan
PostPosted: Wed Mar 31, 2010 1:14 pm Up
Looked at the 206cc today but didn't have time to speak to a master tech.The car had the 6242z8 stalk fitted and i was able to check if there was a brake switch on the brake pedal next to where the clutch switch is fitted but nothing fitted there.The salesman wouldn't let me remove the carpet trim under the glovebox to check the brake switch to see if it had 2 or 4 wire on it which was a shame.I did notice though,ESP was fitted.I also took down the VIN number as it might help with looking on servicebox for the parts needed.
2005/55 Reg 2.0 HDi 3Dr Sport in Aegean blue.
16" 307 wheels refurbished
New genuine silver dials with oil temp gauge now working too!
Rear Spolier,SP lexus rear lights,SP arches,SP bonnet grille,Sp front grille.SP bumper grille.
Locking leather covered glovebox.
Clifford cat 1 alarm
Recaro seats and rear seats trimmed to match.
Headlamp wash almost done
Gti 180 rear bumper
Morette headlights
Gti 180 carbon effect trim
Alloy stubby aerial
Centre armrest
Black alloy tax disc holder
Gti 180 carbon fibre effect door mirror caps
Carbon fibre effect door card pulls
vintageoriginal
PostPosted: Wed Mar 31, 2010 2:59 pm Up
good work HDiMan!
Quiksilver: 1.6 16v Engine Conversion.
HDiMan
PostPosted: Thu Apr 01, 2010 10:45 am Up
The 206cc i looked at has a different brake switch p/n 5434.40
This is fitted to cars with Regulator or speed limit (cruise control i think?)
OR
ESP.
My car has the std brake switch 4534.44 and i have no idea what the difference is yet ie 2 or 4 wire.
So I reckonn if you have ESP fitted,then yes you should be able to retro fit cruise control with a stalk and a BSI/ECU UPDATE.
I cannot find any other parts needed or different looms yet.
Gti 180 rear bumper
Morette headlights
Alloy stubby aerial
Centre armrest
HDiMan
PostPosted: Fri Apr 02, 2010 12:46 pm Up
Been on several german 206 sites
Further update -
1.1,1.4,2.0 (138) petrol engines and 1.4,1.6 HDi Diesel engines cruise contol has not been able to be retro fitted with original equipment on multiplexed cars.
1.6 (110) petrol engine is the best engine to sucessfully have cc retro fitted if your BSI hasn't been locked at the factory or been updated.2002-2004 models has the most success rate about 80%.If your BSI is locked it can be unlocked by dealer if they can give Pug in France a chassis number from a car that had it factory fitted.
2.0 HDi Diesel engines - no idea as i found no info.
2.0 RC which is the equivalent of GTi 180 here - 50% success rate,again depends on BSI being unlocked,unfortunately if it's locked no way around it i'm afraid.
Gti 180 rear bumper
Morette headlights
Alloy stubby aerial
Centre armrest
Lecktorious
PostPosted: Mon Apr 05, 2010 4:41 pm Up
Trade Rating: +59
Bit of a pain in the nuts it can't be done on the HDi 110.
Did you get a chance to speak to the Tech at all?
'98 Nile Blue 306 GTi 6
HDiMan
PostPosted: Fri Apr 09, 2010 8:02 am Up
Brake switch p/n 5434.40 has four connections and has a dome on the plunger.I haven't been able to speak to a master tech yet,tried twice but they have been too busy!
Gti 180 rear bumper
Morette headlights
Alloy stubby aerial
Centre armrest
Joe
PostPosted: Wed Apr 14, 2010 11:27 am Up
Fail
1.6 HDi. . . . The worst engine ever made
wagsy206
PostPosted: Wed Apr 14, 2010 11:54 am Up
just get one with cruise control fitted, lol. ive just spent £4995 to get cruise control ha ha ha.
HONDA FTW!!
Wagsy206
old post count: 5000+
Team: Honda Accord
Lecktorious
PostPosted: Wed Apr 14, 2010 1:57 pm Up
Trade Rating: +59
Post up your findings when you've spoken to him Very Happy
skard
PostPosted: Wed Apr 14, 2010 2:00 pm Up
if anyone's interested, i'm selling my cruise control stalk
will also be selling my PP2000 cable soon too.
andrew96
PostPosted: Sun Apr 25, 2010 4:52 pm Up
Hi everyone
I have just found this thread and been reading with intrest
I too am wanting CC and YES have been sucessfull in fitting it! read on!
Mine is a 2006 206 verve 1.4 HDI (55 plate but registered Jan 2006) and MULTIPLEXED
It DOES have the 4 wire brake switch 5434.40 and the clutch switch 4534.28
The control i got was the 6242 Z9 one as the ebay seller sent me the wrong one! (wanted Z8)
i put it in the com2000 steering unit
used PP to change the BSI to CC present, fine
and ECU DID change to present on mine!
The instrument cluster would change to 'cruise control type 1 with/without speed restrictor' i set, then saved and it said download faulty, then doing a check the value changed to INVALID, but left it like that
took the car out for a run tonight, got to 55mph, switched CC on and took foot off accelerator, car slowed, its not working i thought, then when it got to 50 it stayed there! pressing the up button on the stalk car increased speed! press pause and deaccelerates, press pause again and car goes back up to cruise speed! so its working, but the instrument panel shows nothing of the CC, no CC50 comes up in it so guessing it seems for CC to work it needs the BSI and engine ECU enabled.
My next move is to send the CC control back to the ebay seller and get the right one with the limiter on as well
Hope this helps abit with the quest for everyone! i have managed it
cheers
Andrew
andrew96
PostPosted: Sun Apr 25, 2010 4:54 pm Up
what CC is it? is it the one with the limiter on? if it is i am interested
cheers
Andrew
skard
PostPosted: Sun Apr 25, 2010 5:34 pm Up
cheers
Andrew
it sold, sorry.
andrew96
PostPosted: Sun Apr 25, 2010 5:38 pm Up
skard wrote:
cheers
Andrew
it sold, sorry.
cheers no worries, will get the ebay seller to send the right one so hopefully the limiter part will work too
thanks again
Andrew
wagsy206
PostPosted: Mon Apr 26, 2010 11:18 am Up
so, even though it says "invalid" and said download faulty, it still worked?
Wagsy206
Team: Honda Accord
Page 30 of 36
