Online Now [1469]:
Visitors: 1468
Today: 107732
Total: 149181887
Forums › The Car › Photoshoot Gallery › Shell Shocked Autobodies LTD Work Portfolio
-SDC-
PostPosted: Fri Apr 23, 2010 2:21 pm Up
Edward wrote:
Why has overspray been allowed to get on the wheel arch liners on the Astra? Even though it's on the back of them they should have been removed or masked.
Edward, if you look a little closer you will see that the arch liner has acturly been removed and the back of that is the metal base. Even though the arch liner will cover this we always underseal arch liners when finished, as we did on the supra. There is no point in masking this area up, its always full of muck and you never find a easy surface to mask to. Plus if you pasting a transparent colour, the pressure on the gun will be high and at this point a small opening on a masked panel will allow overspray to entire. You always no matter how good your masking is get area's of over spraying, hence why you allow up to 2 days for flatting, polisihing and rectification works.
The pink in itself is an awesome awesome colour, extreamly hard to spray, mega perly.
I also have finished pictures of the supra now, with new wheels and having been fully valleted by the guys. Owner was over the moon and has booked his girlfriends and his mates supra in for immediate work.
On the spoiler side of things, it looks like thats been sprayed from factory on the plastic gel coat (which arguably is a primer). However there is some type of reaction going on there (I would guess involing heat and solvents escaping from the plastic).
The remady would to be sand the spoiler back down, lay primer on heavily and then respray. The paint looks very thin there as well.
-SDC-
PostPosted: Mon Apr 26, 2010 2:15 am Up
Supra is now finished! One very happy customer came to pick the car up on friday. Also dropped his girl friends supra with us for more of the same treatment!
Astra's now bean laqured:
mattievrs
PostPosted: Mon Apr 26, 2010 2:21 am Up
looks really good mate, i wonder why youve sprayed the exhaust on the supra though?
NO LONGER ACTIVE ON THE FORUM
-SDC-
PostPosted: Mon Apr 26, 2010 2:29 am Up
New exhaust next week apparently, we started to take it off and got meet with "what are you doing that for!" Laughing Customers king as they say!
mattievrs
PostPosted: Mon Apr 26, 2010 2:31 am Up
cool, looks a godd job/finish.
Nitrox121
PostPosted: Mon Apr 26, 2010 2:36 am Up
Awesome work...
ill hopefully be e-mailing you some pictures next week with your opinion on some work id like doing, if thats ok, always good to have a proffesional advise Smile
Die Hard Member - Back For Round 2 -
New Car: BMW 318 Ti Compact M Sport
-SDC-
PostPosted: Mon Apr 26, 2010 2:52 am Up
Nitrox121 wrote:
Awesome work...
I would be happy to Smile
-SDC-
PostPosted: Thu Apr 29, 2010 5:46 am Up
Corsa Repaired!
Also rust removal on some sills:
-SDC-
PostPosted: Fri May 14, 2010 2:38 am Up
Further Update on a few things I been able to point a Camera at recently.
This Civic had gone into a wall and had a load of deep scuffs:
A Merc Vario Van that had been involved in a front end smack:
Also a rear end repair on a Coger:
apjs87
PostPosted: Fri May 14, 2010 3:32 am Up
hi mate, did you get my email?
No longer a 206 owner
Astra H sxi. 1.7Cdti
-SDC-
PostPosted: Fri May 14, 2010 4:15 am Up
Hello my friend,
yes I did, I will be getting back to you with my advice and a couple of prices by the end of the day Smile
bullous206
PostPosted: Fri May 14, 2010 12:23 pm Up
how much to have a 206's side strips smoothed out? or to get them colour coeded?
cheers
206 lx, 1998, 1.4 8v, 16" nimrods, standard rear lights, cupra front splitter, also has new number plate styling, im feeling the euro style Smile (eventualy)
-SDC-
PostPosted: Mon May 17, 2010 6:07 am Up
cheers
Hi mate,
Smoothing the side strips is a massive task, there are fixing holes and a hard swag line to rebuild.
Colour coding them is pretty easy, If there textured then I will say £121 to spray both sides.
Hope that helps!
bullous206
PostPosted: Fri May 21, 2010 9:51 am Up
beaut, what about the front and back bumper strips?
-SDC-
PostPosted: Tue May 25, 2010 5:29 am Up
I recon around the 160 mark, there a little bit bigger!
Page 4 of 5
